주요 콘텐츠로 건너뛰기
LG Realm Motherboard Replacement
필요한 것
  1. LG Realm Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Realm Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Motherboard Replacement, Plastic Midframe: 3 단계, 이미지 2개 중 1개 LG Realm Motherboard Replacement, Plastic Midframe: 3 단계, 이미지 2개 중 2개
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Motherboard Replacement, Rear Facing Camera: 5 단계, 이미지 1개 중 1개
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
  7. LG Realm Motherboard Replacement, Front Facing Camera: 7 단계, 이미지 1개 중 1개
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  8. LG Realm Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
  9. LG Realm Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
  10. LG Realm Motherboard Replacement: 10 단계, 이미지 2개 중 1개 LG Realm Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
  11. LG Realm Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
  12. LG Realm Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan St Martin
회원 가입일: 03/05/16
785 평판
안내서 4개를 작성함
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G5
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 11
전체 시간: 1,306
