주요 콘텐츠로 건너뛰기
LG Realm Plastic Midframe Replacement
필요한 것
  1. LG Realm Plastic Midframe Replacement, Battery: 1 단계, 이미지 1/2 LG Realm Plastic Midframe Replacement, Battery: 1 단계, 이미지 2/2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Plastic Midframe Replacement: 2 단계, 이미지 1/1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Plastic Midframe Replacement, Plastic Midframe: 3 단계, 이미지 1/2 LG Realm Plastic Midframe Replacement, Plastic Midframe: 3 단계, 이미지 2/2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Plastic Midframe Replacement: 4 단계, 이미지 1/1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ryan St Martin
회원 가입일: 03/05/16
770 평판
안내서 4개 작성하였습니다
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G5
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 313
