소개
Before continuing, make sure the device is powered down.
필요한 것
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
