주요 콘텐츠로 건너뛰기
LG Rebel Front Camera Replacement
필요한 것
  1. LG Rebel Front Camera Replacement, Front Camera: 1 단계, 이미지 1/3 LG Rebel Front Camera Replacement, Front Camera: 1 단계, 이미지 2/3 LG Rebel Front Camera Replacement, Front Camera: 1 단계, 이미지 3/3
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: 2 단계, 이미지 1/3 LG Rebel Front Camera Replacement: 2 단계, 이미지 2/3 LG Rebel Front Camera Replacement: 2 단계, 이미지 3/3
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: 3 단계, 이미지 1/3 LG Rebel Front Camera Replacement: 3 단계, 이미지 2/3 LG Rebel Front Camera Replacement: 3 단계, 이미지 3/3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: 4 단계, 이미지 1/2 LG Rebel Front Camera Replacement: 4 단계, 이미지 2/2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: 5 단계, 이미지 1/3 LG Rebel Front Camera Replacement: 5 단계, 이미지 2/3 LG Rebel Front Camera Replacement: 5 단계, 이미지 3/3
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: 6 단계, 이미지 1/2 LG Rebel Front Camera Replacement: 6 단계, 이미지 2/2
    • Remove the front camera by its tail with a spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lesley Sigaran
회원 가입일: 02/08/18
145 평판
안내서 1개 작성함
Sam Houston State, Team S16-G2, Nardone Spring 2018 Sam Houston State, Team S16-G2, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 359
