주요 콘텐츠로 건너뛰기
LG Rebel Rear Camera Replacement
필요한 것
  1. LG Rebel Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/2 LG Rebel Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: 2 단계, 이미지 1/3 LG Rebel Rear Camera Replacement: 2 단계, 이미지 2/3 LG Rebel Rear Camera Replacement: 2 단계, 이미지 3/3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: 3 단계, 이미지 1/2 LG Rebel Rear Camera Replacement: 3 단계, 이미지 2/2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: 4 단계, 이미지 1/3 LG Rebel Rear Camera Replacement: 4 단계, 이미지 2/3 LG Rebel Rear Camera Replacement: 4 단계, 이미지 3/3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: 5 단계, 이미지 1/3 LG Rebel Rear Camera Replacement: 5 단계, 이미지 2/3 LG Rebel Rear Camera Replacement: 5 단계, 이미지 3/3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: 6 단계, 이미지 1/2 LG Rebel Rear Camera Replacement: 6 단계, 이미지 2/2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: 7 단계, 이미지 1/3 LG Rebel Rear Camera Replacement: 7 단계, 이미지 2/3 LG Rebel Rear Camera Replacement: 7 단계, 이미지 3/3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: 8 단계, 이미지 1/2 LG Rebel Rear Camera Replacement: 8 단계, 이미지 2/2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emma Johnson
회원 가입일: 02/08/18
184 평판
안내서 1개 작성함
Sam Houston State, Team S16-G2, Nardone Spring 2018 Sam Houston State, Team S16-G2, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 487
