주요 콘텐츠로 건너뛰기
LG Refrigerator Condenser Fan Motor Replacement
필요한 것
  1. LG Refrigerator Condenser Fan Motor Replacement, Unplug your refrigerator: 1 단계, 이미지 1/1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser cover: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the screws securing the condenser cover to the rear of the refrigerator.
  3. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 3 단계, 이미지 1/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 3 단계, 이미지 2/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 3 단계, 이미지 3/3
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: 4 단계, 이미지 1/2 LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: 4 단계, 이미지 2/2
    • Squeeze and pull the condenser fan connector straight down to disconnect the condenser fan.
  5. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser fan shroud: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the condenser fan shroud screw.
  6. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 6 단계, 이미지 1/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 6 단계, 이미지 2/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 6 단계, 이미지 3/3
    • Place a pair of slip joint pliers around the condenser fan drive shaft.
    • Place a large flat blade screwdriver between the slip joint pliers and the fan hub.
    • While holding the pliers in place, push the screwdriver against the pliers to pry the fan off.
  7. LG Refrigerator Condenser Fan Motor Replacement: 7 단계, 이미지 1/2 LG Refrigerator Condenser Fan Motor Replacement: 7 단계, 이미지 2/2
    • Remove the fan blade assembly.
  8. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 8 단계, 이미지 1/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 8 단계, 이미지 2/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 8 단계, 이미지 3/3
    • Use a stubby Phillips screwdriver to remove the screws securing the fan motor inside the fan motor bracket.
    • You may find it easier to use a 1/4 inch drive socket with a Phillips head bit to remove the screws.
  9. LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 9 단계, 이미지 1/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 9 단계, 이미지 2/3 LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 9 단계, 이미지 3/3
    • Push apart the two halves of the fan motor bracket to release the fan motor.
    • Slide the fan motor shaft up through the slot in the front fan motor bracket.
  10. LG Refrigerator Condenser Fan Motor Replacement: 10 단계, 이미지 1/2 LG Refrigerator Condenser Fan Motor Replacement: 10 단계, 이미지 2/2
    • Remove the fan motor.
  11. LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 11 단계, 이미지 1/3 LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 11 단계, 이미지 2/3 LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 11 단계, 이미지 3/3
    • Transfer the two rubber motor mounting washers from the old motor to the new motor.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
30,088 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,410개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 34
30일 전: 146
전체 시간: 482
