주요 콘텐츠로 건너뛰기
LG Refrigerator Ice Auger Motor Run Capacitor Replacement
필요한 것
  1. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unplug your refrigerator: 1 단계, 이미지 1/1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unfasten the control board cover: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 1/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 2/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 3/3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: 4 단계, 이미지 1/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: 4 단계, 이미지 2/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: 4 단계, 이미지 3/3
    • Squeeze and pull the connectors to disconnect them:
    • Connectors from the control board
    • Connectors from the refrigerator
    • Some connectors can remain connected as the wires attached to them don't get in the way. There is no harm if they are disconnected. Remember to reconnect them if disconnected.
  5. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: 5 단계, 이미지 1/2 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: 5 단계, 이미지 2/2
    • Reposition the wiring harness away from the capacitor.
  6. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: 6 단계, 이미지 1/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: 6 단계, 이미지 2/3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: 6 단계, 이미지 3/3
    • Pull the two connectors straight off the capacitor to disconnect it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • Information on capacitor safety.
  7. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: 7 단계, 이미지 1/2 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: 7 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the screw securing the capacitor to the refrigerator.
    • Remove the capacitor.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
30,797 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,067개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 131
