주요 콘텐츠로 건너뛰기
LG Refrigerator LFX25973 Dispenser PC Board Replacement
필요한 것
  1. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Loosen the left door handle set screws: 2 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Loosen the left door handle set screws: 2 단계, 이미지 2개 중 2개
    • To remove the left door handle, first open the right door.
    • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
  3. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the left door handle: 3 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the left door handle: 3 단계, 이미지 2개 중 2개
    • Pull the left door handle straight off to remove it.
  4. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Retaining clip locations: 4 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Retaining clip locations: 4 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Retaining clip locations: 4 단계, 이미지 3개 중 3개
    • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip locations shown in the photos:
    • Right side clips
    • Top clips
    • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
    • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
  5. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the dispenser: 5 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the dispenser: 5 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the dispenser: 5 단계, 이미지 3개 중 3개
    • Use a spudger to pry out the top edge of the dispenser assembly.
    • Once you've created a gap, use your fingertips to pull the edge downward.
    • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
    • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
  6. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Reposition the dispenser: 6 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Reposition the dispenser: 6 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Reposition the dispenser: 6 단계, 이미지 3개 중 3개
    • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
    • Continue prying and pulling around the perimeter of the assembly to release it.
  7. LG Refrigerator LFX25973 Dispenser PC Board Replacement: 7 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement: 7 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement: 7 단계, 이미지 3개 중 3개
    • Grasp the assembly firmly and pull it out of the refrigerator door.
    • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
  8. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Disconnect the dispenser: 8 단계, 이미지 1개 중 1개
    • Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
    • Do not attempt to remove the four-wire connector from the board as it is not removable.
  9. LG Refrigerator LFX25973 Dispenser PC Board Replacement: 9 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement: 9 단계, 이미지 2개 중 2개
    • Squeeze and separate the two-wire harness connector and the four-wire harness connector.
  10. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Unfasten the circuit board holder: 10 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Unfasten the circuit board holder: 10 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Unfasten the circuit board holder: 10 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
    • Lift and remove the circuit board holder from the dispenser assembly.
  11. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the dispenser: 11 단계, 이미지 1개 중 1개
    • You can now remove the dispenser from the refrigerator.
    • The white circuit board holder can be suspended from the harness wires, as its weight is minimal.
  12. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the tape: 12 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the tape: 12 단계, 이미지 2개 중 2개
    • Peel off the tape securing the cover of the circuit board holder.
  13. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the circuit board holder cover: 13 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the circuit board holder cover: 13 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Release the circuit board holder cover: 13 단계, 이미지 3개 중 3개
    • Push the wing of the circuit board holder cover toward the wires to release it.
    • Slide the circuit board holder cover off of the circuit board holder and remove it.
  14. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Disconnect the dispenser PC board: 14 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Disconnect the dispenser PC board: 14 단계, 이미지 2개 중 2개
    • Squeeze and pull the first of three connectors straight off to disconnect it from the circuit board.
  15. LG Refrigerator LFX25973 Dispenser PC Board Replacement: 15 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement: 15 단계, 이미지 2개 중 2개
    • Continue removing the two remaining connectors.
  16. LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the dispenser PC board: 16 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Dispenser PC Board Replacement, Remove the dispenser PC board: 16 단계, 이미지 2개 중 2개
    • Use a Philips screwdriver to remove the 10 mm screw securing the circuit board to the circuit board holder.
    • Lift off the circuit board and remove it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
38,497 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 168
