주요 콘텐츠로 건너뛰기
LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement
필요한 것
  1. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Open the freezer door: 2 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Open the freezer door: 2 단계, 이미지 2개 중 2개
    • Pull open the freezer door fully.
  3. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 3개
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 3개
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Reassembly notes: 5 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Reassembly notes: 5 단계, 이미지 2개 중 2개
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer: 6 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the drawer: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement: 7 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement: 7 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release the drawer slides: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 22.4 mm‑long screws securing both left drawer slides.
  9. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the upper left drawer slide: 9 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the upper left drawer slide: 9 단계, 이미지 2개 중 2개
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: 10 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: 10 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: 10 단계, 이미지 3개 중 3개
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: 11 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: 11 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: 11 단계, 이미지 3개 중 3개
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, only the left-hand slides need to be removed.
  12. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Test the door switch: 12 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Test the door switch: 12 단계, 이미지 2개 중 2개
    • If you have a multimeter, you can test the freezer door switch for continuity.
    • Set the multimeter to the ohm setting.
    • Check continuity between the two orange wire terminals on the connector.
    • The switch should show less than one ohm resistance in the unpressed position.
    • When pressed, the switch should show no connection.
    • If your switch does not function as described above, follow the next steps to remove and replace it.
  13. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the door switch: 13 단계, 이미지 3개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the door switch: 13 단계, 이미지 3개 중 2개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Remove the door switch: 13 단계, 이미지 3개 중 3개
    • Press the retaining tab on the switch to release it from the drawer slide assembly.
    • When it is released, push the switch down through the mounting cutout.
    • Remove the switch from the drawer slide assembly.
  14. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release the wiring from the door switch: 14 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Release the wiring from the door switch: 14 단계, 이미지 2개 중 2개
    • Use a spudger to release the two clips that secure the wiring connector to the door switch.
  15. LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Disconnect the wiring harness from the drawer switch: 15 단계, 이미지 2개 중 1개 LG Refrigerator LFX25973 Freezer Drawer Switch Testing and Replacement, Disconnect the wiring harness from the drawer switch: 15 단계, 이미지 2개 중 2개
    • Pull the connector straight off the drawer switch to disconnect it.
    • Disconnecting this connector may require considerable force.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
38,497 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 208
