주요 콘텐츠로 건너뛰기
LG Refrigerator Light Replacement
필요한 것
  1. LG Refrigerator Light Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Light Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 LG Refrigerator Light Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 LG Refrigerator Light Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Open both refrigerator doors fully.
  3. LG Refrigerator Light Replacement, Remove the shelves: 3 단계, 이미지 3개 중 1개 LG Refrigerator Light Replacement, Remove the shelves: 3 단계, 이미지 3개 중 2개 LG Refrigerator Light Replacement, Remove the shelves: 3 단계, 이미지 3개 중 3개
    • Lift up the front edge of the shelf to release it.
    • Unhook the shelf and remove it.
    • Repeat the last two steps for each shelf you wish to remove.
  4. LG Refrigerator Light Replacement, Remove the light unit screws: 4 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the screws that secure the light unit.
  5. LG Refrigerator Light Replacement, Lower the light unit: 5 단계, 이미지 2개 중 1개 LG Refrigerator Light Replacement, Lower the light unit: 5 단계, 이미지 2개 중 2개
    • With both hands, pull down the front edge of the light unit until it pops free.
    • Don't try to fully remove the light unit yet, as it is still connected to the refrigerator by some wires.
  6. LG Refrigerator Light Replacement, Disconnect the light unit: 6 단계, 이미지 3개 중 1개 LG Refrigerator Light Replacement, Disconnect the light unit: 6 단계, 이미지 3개 중 2개 LG Refrigerator Light Replacement, Disconnect the light unit: 6 단계, 이미지 3개 중 3개
    • Pinch the light unit connector to release it and pull it out straight to disconnect.
    • Remove the light unit.
  7. LG Refrigerator Light Replacement, Remove the light cover: 7 단계, 이미지 3개 중 1개 LG Refrigerator Light Replacement, Remove the light cover: 7 단계, 이미지 3개 중 2개 LG Refrigerator Light Replacement, Remove the light cover: 7 단계, 이미지 3개 중 3개
    • Use a spudger to pry and release the two clips on the rear edge of the light.
  8. LG Refrigerator Light Replacement: 8 단계, 이미지 3개 중 1개 LG Refrigerator Light Replacement: 8 단계, 이미지 3개 중 2개 LG Refrigerator Light Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger to pry and release the sides of the light cover from the light base.
  9. LG Refrigerator Light Replacement: 9 단계, 이미지 1개 중 1개
    • Separate the light base from the light cover.
  10. LG Refrigerator Light Replacement, Remove the light module: 10 단계, 이미지 1개 중 1개
    • Use a Philips head driver to remove the screws securing the light module.
  11. LG Refrigerator Light Replacement: 11 단계, 이미지 2개 중 1개 LG Refrigerator Light Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the light module out of the light base and remove it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,497 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 94
전체 시간: 1,102
