주요 콘텐츠로 건너뛰기
LG Refrigerator Model LFX25973 Freezer Light Replacement
필요한 것
  1. LG Refrigerator Model LFX25973 Freezer Light Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator Model LFX25973 Freezer Light Replacement, Open the freezer door: 2 단계, 이미지 2개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Open the freezer door: 2 단계, 이미지 2개 중 2개
    • Pull open the freezer door fully.
  3. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 2개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 3개
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 2개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 3개
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Model LFX25973 Freezer Light Replacement, Reassembly notes: 5 단계, 이미지 2개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Reassembly notes: 5 단계, 이미지 2개 중 2개
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer: 6 단계, 이미지 2개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Model LFX25973 Freezer Light Replacement: 7 단계, 이미지 3개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement: 7 단계, 이미지 3개 중 2개 LG Refrigerator Model LFX25973 Freezer Light Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Model LFX25973 Freezer Light Replacement, Unfasten the freezer light: 8 단계, 이미지 2개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Unfasten the freezer light: 8 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 22 mm‑long screw securing the freezer light.
    • Lower the front edge of the freezer light to access its connector.
  9. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: 9 단계, 이미지 3개 중 1개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: 9 단계, 이미지 3개 중 2개 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: 9 단계, 이미지 3개 중 3개
    • Squeeze the freezer light connector and pull it straight off to disconnect it.
    • Remove the freezer light.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
38,500 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 141
