주요 콘텐츠로 건너뛰기
LG Refrigerator Upper Ice Maker Assembly Replacement
필요한 것
  1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: 1 단계, 이미지 1/1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 1/3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 2/3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 3/3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 3 단계, 이미지 1/2 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 3 단계, 이미지 2/2
    • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
  4. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 1/3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 2/3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 3/3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  5. LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 1/3 LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 2/3 LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 3/3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  6. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: 6 단계, 이미지 1/1
    • Remove the ice maker assembly.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
30,088 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,410개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 34
전체 시간: 129
