주요 콘텐츠로 건너뛰기
LG Risio Front Camera Replacement
필요한 것
  1. LG Risio Front Camera Replacement, Back Panel: 1 단계, 이미지 1/2 LG Risio Front Camera Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Front Camera Replacement, Battery: 2 단계, 이미지 1/1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Front Camera Replacement, Midframe: 3 단계, 이미지 1/1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Front Camera Replacement: 4 단계, 이미지 1/2 LG Risio Front Camera Replacement: 4 단계, 이미지 2/2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Front Camera Replacement: 5 단계, 이미지 1/3 LG Risio Front Camera Replacement: 5 단계, 이미지 2/3 LG Risio Front Camera Replacement: 5 단계, 이미지 3/3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Front Camera Replacement: 6 단계, 이미지 1/1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Front Camera Replacement, Front-Facing Camera: 7 단계, 이미지 1/2 LG Risio Front Camera Replacement, Front-Facing Camera: 7 단계, 이미지 2/2
    • Unclip the front camera connector from the motherboard and lift it from the frame.
결론
Amina
회원 가입일: 02/21/18
73 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 8
전체 시간: 171
