소개
If there are a lot of issues on the phone such as the blue screen, the screen not turning on, or the headphone jack not working properly, it may be the motherboard. Use this guide to replace the motherboard to fix the issues listed above.
필요한 것
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
다른 한 분이 해당 안내서를 완성하였습니다.
