주요 콘텐츠로 건너뛰기
LG Risio Motherboard Replacement
필요한 것
  1. LG Risio Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 LG Risio Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: 2 단계, 이미지 1/1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: 3 단계, 이미지 1/1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: 4 단계, 이미지 1/2 LG Risio Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: 5 단계, 이미지 1/3 LG Risio Motherboard Replacement: 5 단계, 이미지 2/3 LG Risio Motherboard Replacement: 5 단계, 이미지 3/3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: 6 단계, 이미지 1/1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 LG Risio Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: 8 단계, 이미지 1/1
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erika Heppner
회원 가입일: 02/21/18
316 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 250
