주요 콘텐츠로 건너뛰기
LG Rumor Touch Camera Lens Replacement
필요한 것
  1. LG Rumor Touch Camera Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. LG Rumor Touch Camera Lens Replacement: 2 단계, 이미지 1/2 LG Rumor Touch Camera Lens Replacement: 2 단계, 이미지 2/2
    • Gently pry the battery out of the phone with the spudger.
  3. LG Rumor Touch Camera Lens Replacement, Inner Shell: 3 단계, 이미지 1/1
    • Unscrew the 5 #1 5mm screws.
  4. LG Rumor Touch Camera Lens Replacement: 4 단계, 이미지 1/1
    • Lift the inner shell from the phone.
  5. LG Rumor Touch Camera Lens Replacement, Camera Lens: 5 단계, 이미지 1/1
    • Push the camera lens though its socket, from the inside out.
결론
Andrew Hodges
회원 가입일: 01/14/14
122 평판
안내서 1개 작성함
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014 회원
CPSU-FORTE-W14S17G2
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 263
