주요 콘텐츠로 건너뛰기
소개
This guide details the process of removing the keyboard from an LG Rumor Touch. Installation of the keyboard can be accomplished by reversing the process.
부품
지정된 부품이 없습니다.
  1. Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. Gently pry the battery out of the phone with the spudger. Gently pry the battery out of the phone with the spudger.
    • Gently pry the battery out of the phone with the spudger.
  3. Unscrew the 5 #1 5mm screws.
    • Unscrew the 5 #1 5mm screws.
  4. Lift the inner shell from the phone.
    • Lift the inner shell from the phone.
  5. Remove the main circuit board.
    • Remove the main circuit board.
    • Remove the keyboard membrane.
결론
Creed Borden
회원 가입일: 2014년 01월 14일
101 평판
안내서 1개 작성함
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014 회원
CPSU-FORTE-W14S17G2
5 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 315
