주요 콘텐츠로 건너뛰기
LG Rumor Touch Motherboard Replacement
필요한 것
  1. LG Rumor Touch Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. LG Rumor Touch Motherboard Replacement: 2 단계, 이미지 1/2 LG Rumor Touch Motherboard Replacement: 2 단계, 이미지 2/2
    • Gently pry the battery out of the phone with the spudger.
  3. LG Rumor Touch Motherboard Replacement, Inner Shell: 3 단계, 이미지 1/1
    • Unscrew the 5 #1 5mm screws.
  4. LG Rumor Touch Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the inner shell from the phone.
  5. LG Rumor Touch Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Unscrew two 2mm #00 screws located behind the white serial code sticker.
  6. LG Rumor Touch Motherboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the ribbon found in the middle of the phone
    • Gently pull the ribbon out of the way.
  7. LG Rumor Touch Motherboard Replacement: 7 단계, 이미지 1/2 LG Rumor Touch Motherboard Replacement: 7 단계, 이미지 2/2
    • Slide open the phone, revealing the QWERTY keyboard.
  8. LG Rumor Touch Motherboard Replacement: 8 단계, 이미지 1/2 LG Rumor Touch Motherboard Replacement: 8 단계, 이미지 2/2
    • Carefully push the mother board through by pressing into the keyboard.
  9. LG Rumor Touch Motherboard Replacement: 9 단계, 이미지 1/1
    • The mother board will fall out of the back along with the silicon keyboard pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jose Rivas
회원 가입일: 01/14/14
134 평판
안내서 1개 작성함
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014 회원
CPSU-FORTE-W14S17G2
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 713
