소개
Before proceeding make sure the necessary tools described in previous guide are within reach.
부품
부품은 필요하지 않습니다.
  1. Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. Gently pry the battery out of the phone with the spudger. Gently pry the battery out of the phone with the spudger.
    • Gently pry the battery out of the phone with the spudger.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Unscrew the 5 #1 5mm screws.
    • Unscrew the 5 #1 5mm screws.
  5. Lift the inner shell from the phone.
    • Lift the inner shell from the phone.
  6. Detach the speaker by pulling with enough force away from the phone. The speaker is weakly glued.
    • Detach the speaker by pulling with enough force away from the phone. The speaker is weakly glued.
결론
Ivan Rojas
회원 가입일: 2014년 01월 14일
104 평판
안내서 1개 작성함
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014 회원
CPSU-FORTE-W14S17G2
5 회원들
안내서 12개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 227
