소개
When replacing a battery make sure to rid the old battery responsibly.You will need the plastic separator tool or if you don't you can use your nails but it is highly not recommended as you could get injured.
필요한 것
First you need to remove the back case of the phone.
Place the phone face down.
Using the plastic opening tool, insert into the initial gap shown.
Slowly guide the tool around the case until the case comes off with ease.
다른 3명이 해당 안내서를 완성하였습니다.
