주요 콘텐츠로 건너뛰기
LG Stylo 2 Motherboard Replacement
필요한 것
  1. LG Stylo 2 Motherboard  Replacement, Battery: 1 단계, 이미지 1/3 LG Stylo 2 Motherboard  Replacement, Battery: 1 단계, 이미지 2/3 LG Stylo 2 Motherboard  Replacement, Battery: 1 단계, 이미지 3/3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: 2 단계, 이미지 1/3 LG Stylo 2 Motherboard  Replacement: 2 단계, 이미지 2/3 LG Stylo 2 Motherboard  Replacement: 2 단계, 이미지 3/3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: 3 단계, 이미지 1/3 LG Stylo 2 Motherboard  Replacement, Rear Camera: 3 단계, 이미지 2/3 LG Stylo 2 Motherboard  Replacement, Rear Camera: 3 단계, 이미지 3/3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: 4 단계, 이미지 1/3 LG Stylo 2 Motherboard  Replacement: 4 단계, 이미지 2/3 LG Stylo 2 Motherboard  Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: 5 단계, 이미지 1/3 LG Stylo 2 Motherboard  Replacement, Motherboard: 5 단계, 이미지 2/3 LG Stylo 2 Motherboard  Replacement, Motherboard: 5 단계, 이미지 3/3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
결론
Devon Barber
회원 가입일: 02/13/18
994 평판
안내서 5개 작성하였습니다
USF Tampa, Team S11-G1, Cheng Spring 2018 USF Tampa, Team S11-G1, Cheng Spring 2018 회원
USFT-CHENG-S18S11G1
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Charging retain 2.1
Kashif Kashi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 2,233
