소개
When your phone becomes water damaged or any other internal damage comes to the motherboard it will become necessary to replace it. This guide will show you exactly how to do so with ease. When touching internal components make sure your hands are very clean or you are wearing gloves.
필요한 것
First you need to remove the back case of the phone.
Place the phone face down.
Using the plastic opening tool, insert into the initial gap shown.
Slowly guide the tool around the case until the case comes off with ease.
Remove the eleven 4mm Phillips #00 screws.
Place screws in safe location.
Use Plastic opener tool to remove inner case.
Gently remove inner case.
Gently flip the cables(shown in red boxes) using the opener tool.
Gently remove the motherboard itself.
Place motherboard on a soft surface to not damage it.
