주요 콘텐츠로 건너뛰기
LG Stylo 2 Plus Mid-Frame Replacement
필요한 것
  1. LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: 1 단계, 이미지 1/3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: 1 단계, 이미지 2/3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: 1 단계, 이미지 3/3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Mid-Frame Replacement, Battery: 2 단계, 이미지 1/3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: 2 단계, 이미지 2/3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: 2 단계, 이미지 3/3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: 3 단계, 이미지 1/2 LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: 3 단계, 이미지 2/2
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
  4. LG Stylo 2 Plus Mid-Frame Replacement: 4 단계, 이미지 1/2 LG Stylo 2 Plus Mid-Frame Replacement: 4 단계, 이미지 2/2
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
결론
Tiffany Wheeler
회원 가입일: 04/22/19
308 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 151
