주요 콘텐츠로 건너뛰기
LG Stylo 2 Plus Speaker Replacement
필요한 것
  1. LG Stylo 2 Plus Speaker Replacement, Rear Case: 1 단계, 이미지 1/3 LG Stylo 2 Plus Speaker Replacement, Rear Case: 1 단계, 이미지 2/3 LG Stylo 2 Plus Speaker Replacement, Rear Case: 1 단계, 이미지 3/3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Speaker Replacement, Battery: 2 단계, 이미지 1/3 LG Stylo 2 Plus Speaker Replacement, Battery: 2 단계, 이미지 2/3 LG Stylo 2 Plus Speaker Replacement, Battery: 2 단계, 이미지 3/3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Speaker Replacement, Speaker: 3 단계, 이미지 1/2 LG Stylo 2 Plus Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • Remove the cover from the phone in order to access the speaker.
    • Using the JIS #000 screwdriver, remove the four 4mm screws around the base of the mid-frame.
  4. LG Stylo 2 Plus Speaker Replacement: 4 단계, 이미지 1/2 LG Stylo 2 Plus Speaker Replacement: 4 단계, 이미지 2/2
    • Insert the metal spudger in the dimple at the base of the mid-frame.
    • Pry upward, removing bottom section of the mid-frame from the phone.
  5. LG Stylo 2 Plus Speaker Replacement: 5 단계, 이미지 1/3 LG Stylo 2 Plus Speaker Replacement: 5 단계, 이미지 2/3 LG Stylo 2 Plus Speaker Replacement: 5 단계, 이미지 3/3
    • Flip the bottom piece of the mid-frame over to show the speaker in the bottom right corner.
    • Using the tweezers, peel back the rubber resting on top of the speaker.
    • Still using the tweezers, grasp the speaker unit and remove it from the mid-frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Noah Kehm
회원 가입일: 04/22/19
241 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 467
