주요 콘텐츠로 건너뛰기
LG Stylo 3 Plus Battery Replacement
필요한 것
  1. LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 1/3 LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 2/3 LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 1/3 LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 2/3 LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Patricia Pires Dias
회원 가입일: 10/26/18
900 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G6
3 회원들
안내서 15개 작성하였습니다
댓글 4개
Thank you for your help. When I took the battery out one of the 4 gold prongs is dirty tried to clean with a toothbrush, do you have any ideas to clean it?
pmorin3887 - 답글
The gold prong in the phone where the battery is
pmorin3887 - 답글
my phone goes from fully charged to 0 in a few minutes, I took the battery out and seen it was a bit bubbled. I have so far bought 3 new batteries for my phone and every time when I turn it on I get invalid battery and it turns off I have left the battery out for a week to reset it but I still get the error when I turn it on… please somebody help
crystalbic - 답글
It is &&^&@@ up you just got to get a new one you know you got to live to die even man-made machines I'm sorry I hope you can find a way to get over it and move on
Deez Blaccnuts -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 22
전체 시간: 3,877
