주요 콘텐츠로 건너뛰기
LG Stylo 3 Plus Display Assembly Replacement
필요한 것
  1. LG Stylo 3 Plus Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Display Assembly Replacement, Battery: 2 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Battery: 2 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Display Assembly Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: 3 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: 3 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: 3 단계, 이미지 3개 중 3개
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 LG Stylo 3 Plus Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Display Assembly Replacement, Front Camera: 5 단계, 이미지 2개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Front Camera: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
  6. LG Stylo 3 Plus Display Assembly Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Gently flip open the flex cable box using a blue plastic opening tool.
    • Carefully remove the motherboard with your hands or a blue plastic opening tool.
    • Make sure all parts are secure while taking out motherboard.
  7. LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: 7 단계, 이미지 2개 중 1개 LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: 7 단계, 이미지 2개 중 2개
    • Remove the headphone jack.
  8. LG Stylo 3 Plus Display Assembly Replacement, Display Assembly: 8 단계, 이미지 1개 중 1개
    • The remaining component is your complete display assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dillon Cooper
회원 가입일: 09/19/19
193 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 1,211
