주요 콘텐츠로 건너뛰기
LG Stylo 3 Plus Front Camera Replacement
필요한 것
  1. LG Stylo 3 Plus Front Camera Replacement, Back Cover: 1 단계, 이미지 1/3 LG Stylo 3 Plus Front Camera Replacement, Back Cover: 1 단계, 이미지 2/3 LG Stylo 3 Plus Front Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Front Camera Replacement, Battery: 2 단계, 이미지 1/3 LG Stylo 3 Plus Front Camera Replacement, Battery: 2 단계, 이미지 2/3 LG Stylo 3 Plus Front Camera Replacement, Battery: 2 단계, 이미지 3/3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Front Camera Replacement, Rear Camera: 3 단계, 이미지 1/3 LG Stylo 3 Plus Front Camera Replacement, Rear Camera: 3 단계, 이미지 2/3 LG Stylo 3 Plus Front Camera Replacement, Rear Camera: 3 단계, 이미지 3/3
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Front Camera Replacement: 4 단계, 이미지 1/2 LG Stylo 3 Plus Front Camera Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Front Camera Replacement, Front Camera: 5 단계, 이미지 1/2 LG Stylo 3 Plus Front Camera Replacement, Front Camera: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patricia Pires Dias
회원 가입일: 10/26/18
900 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G6
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 813
