소개
This guide will walk you through the steps of removing the midframe of your LG Sunrise.
필요한 것
5 단계 Lower Back Plastic Piece
주의: 5-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
다른 한 분이 해당 안내서를 완성하였습니다.
