주요 콘텐츠로 건너뛰기
LG TP 1100 Microphone Replacement
필요한 것
  1. LG TP 1100 Microphone Replacement, Microphone: 1 단계, 이미지 1/1
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
  2. LG TP 1100 Microphone Replacement: 2 단계, 이미지 1/1
    • You will remove antenna by pulling it in an upward motion away from the socket.
  3. LG TP 1100 Microphone Replacement: 3 단계, 이미지 1/1
    • Turn phone so that the back is facing you.
  4. LG TP 1100 Microphone Replacement: 4 단계, 이미지 1/1
    • Use your thumb to pull the tab in an upward motion to release the battery.
  5. LG TP 1100 Microphone Replacement: 5 단계, 이미지 1/1
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
  6. LG TP 1100 Microphone Replacement: 6 단계, 이미지 1/1
    • Use your screwdriver to unscrew the four screws from the back plate.
  7. LG TP 1100 Microphone Replacement: 7 단계, 이미지 1/1
    • Turn phone to the side as indicated in the picture.
  8. LG TP 1100 Microphone Replacement: 8 단계, 이미지 1/1
    • Remove the back cover that you just unscrewed and set aside.
  9. LG TP 1100 Microphone Replacement: 9 단계, 이미지 1/1
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
  10. LG TP 1100 Microphone Replacement: 10 단계, 이미지 1/2 LG TP 1100 Microphone Replacement: 10 단계, 이미지 2/2
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
  11. LG TP 1100 Microphone Replacement: 11 단계, 이미지 1/1
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnny Inlow
회원 가입일: 04/10/10
19 평판
안내서 3개 작성하였습니다
Cal Poly, Team 27-91, Amido Spring 2010 Cal Poly, Team 27-91, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G91
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,289
