주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Thrill 4G Motherboard Replacement
필요한 것
  1. LG Thrill 4G Motherboard Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 1개 LG Thrill 4G Motherboard Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Motherboard Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 LG Thrill 4G Motherboard Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Motherboard Replacement, Screw Removal: 3 단계, 이미지 1개 중 1개
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Motherboard Replacement, Speaker Removal: 4 단계, 이미지 2개 중 1개 LG Thrill 4G Motherboard Replacement, Speaker Removal: 4 단계, 이미지 2개 중 2개
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Motherboard Replacement, Buttons: 5 단계, 이미지 1개 중 1개
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Motherboard Replacement: 6 단계, 이미지 3개 중 1개 LG Thrill 4G Motherboard Replacement: 6 단계, 이미지 3개 중 2개 LG Thrill 4G Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 1개 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 2개 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 3개
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 1개 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 2개 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 3개
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
  10. LG Thrill 4G Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 LG Thrill 4G Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or spudger to gently disconnect the ribbon cables connected to the motherboard.
    • Disconnect the antenna cable from the bottom right corner of the motherboard.
  11. LG Thrill 4G Motherboard Replacement: 11 단계, 이미지 2개 중 1개 LG Thrill 4G Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a spudger or pair of tweezers to grab the top left corner of the motherboard and gently lift it out, taking care to not damage any of the ribbon cables when removing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Luis Mena
회원 가입일: 01/20/15
270 평판
안내서 2개를 작성함
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 36
전체 시간: 756
