주요 콘텐츠로 건너뛰기
LG Tone Active HBS-850 Speaker Replacement
필요한 것
  1. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: 1 단계, 이미지 2개 중 1개 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: 1 단계, 이미지 2개 중 2개
    • Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
  2. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Screw: 2 단계, 이미지 1개 중 1개
    • Remove hidden screw using a Philips #00 screwdriver.
  3. LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: 3 단계, 이미지 2개 중 1개 LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: 3 단계, 이미지 2개 중 2개
    • Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
  4. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: 4 단계, 이미지 2개 중 1개 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently remove the pointy rubber covering using tweezers where the speaker rests as shown in the picture.
  5. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: 5 단계, 이미지 2개 중 1개 LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: 5 단계, 이미지 2개 중 2개
    • Use a Philips #00 screwdriver to remove the hidden screw.
  6. LG Tone Active HBS-850 Speaker Replacement, Remove Speaker Screw: 6 단계, 이미지 1개 중 1개
    • Remove the screw holding the speaker in place using a Philips #00 screwdriver.
  7. LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: 7 단계, 이미지 2개 중 1개 LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: 7 단계, 이미지 2개 중 2개
    • Desolder speaker connection using a soldering iron and replace with new speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Faizan Naveed
회원 가입일: 04/12/17
3,381 평판
안내서 8개를 작성함
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 17개를 작성함
4가이드 댓글
Do you know of a place to buy a replacement speaker?
James Cimabue - 답글
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
Jim Husselman - 답글
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
Rajesh Narayanan - 답글
Cant find anywhere to buy replacement speakers!
tom - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 2,702
