주요 콘텐츠로 건너뛰기
LG Tone Infinim HBS-910 Battery Replacement
필요한 것
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 1 단계, 이미지 1/3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 1 단계, 이미지 2/3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 1 단계, 이미지 3/3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: 2 단계, 이미지 1/2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: 2 단계, 이미지 2/2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 3 단계, 이미지 1/3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 3 단계, 이미지 2/3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 3 단계, 이미지 3/3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 4 단계, 이미지 1/3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 4 단계, 이미지 2/3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 4 단계, 이미지 3/3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
결론
다른 13명이 해당 안내서를 완성하였습니다.
Faizan Naveed
회원 가입일: 04/12/17
3,294 평판
안내서 8개 작성하였습니다
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 16개 작성하였습니다
댓글 2개
Battery model and amps
honda kung - 답글
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 36
전체 시간: 11,354
