주요 콘텐츠로 건너뛰기
LG Tone Pro HBS-760 Speaker Replacement
필요한 것
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 1 단계, 이미지 1/3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 1 단계, 이미지 2/3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 1 단계, 이미지 3/3
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: 2 단계, 이미지 1/2 LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: 2 단계, 이미지 2/2
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 3 단계, 이미지 1/3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 3 단계, 이미지 2/3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 3 단계, 이미지 3/3
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 4 단계, 이미지 1/3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 4 단계, 이미지 2/3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 4 단계, 이미지 3/3
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: 5 단계, 이미지 1/1
    • Once the speakers have been de-soldered, replace with new ones.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Faizan Naveed
회원 가입일: 04/12/17
3,294 평판
안내서 8개 작성하였습니다
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 1,496
