주요 콘텐츠로 건너뛰기
LG Tone Pro HBS-770 Speaker Replacement
필요한 것
  1. LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 1 단계, 이미지 1/3 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 1 단계, 이미지 2/3 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 1 단계, 이미지 3/3
    • There are 2 hidden screws that need to be removed.
    • Remove the rubber covering that covers the hidden screws.
  2. LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: 2 단계, 이미지 1/2 LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: 2 단계, 이미지 2/2
    • Remove both of the hidden screws using a Philips #00 screwdriver.
  3. LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 3 단계, 이미지 1/3 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 3 단계, 이미지 2/3 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 3 단계, 이미지 3/3
    • Use a guitar pick or any pry opening tool to open the housing.
  4. LG Tone Pro HBS-770 Speaker Replacement, Remove Speaker: 4 단계, 이미지 1/1
    • Desolder speaker connection from board using a solder iron.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Faizan Naveed
회원 가입일: 04/12/17
3,294 평판
안내서 8개 작성하였습니다
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 16개 작성하였습니다
댓글 3개
where do you get the parts
Blaize Lucas - 답글
where to you get the replacement part
Blaize Lucas - 답글
Cannibalize another headphone set typically one that is wired and steal the wires from it to replace the worn ones assuming the original speakers aren't blown
michaelwilkins437 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 2,354
