주요 콘텐츠로 건너뛰기
LG Tone Pro HBS750 Magnet Replacement
필요한 것
  1. LG Tone Pro HBS750 Magnet Replacement, Magnet: 1 단계, 이미지 1/2 LG Tone Pro HBS750 Magnet Replacement, Magnet: 1 단계, 이미지 2/2
    • Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw.
  2. LG Tone Pro HBS750 Magnet Replacement: 2 단계, 이미지 1/1
    • Remove the small screw from the underside of the device and place it aside.
  3. LG Tone Pro HBS750 Magnet Replacement: 3 단계, 이미지 1/1
    • Place a small prying tool in between the two cases and slowly push the two apart. Be sure not to force the case apart, as it may snap in the process.
  4. LG Tone Pro HBS750 Magnet Replacement: 4 단계, 이미지 1/1
    • Once the case is open, the small magnet is now visible and can be replaced.
  5. LG Tone Pro HBS750 Magnet Replacement: 5 단계, 이미지 1/1
    • Once the new magnet is in place, the casing can be pushed back together.
  6. LG Tone Pro HBS750 Magnet Replacement: 6 단계, 이미지 1/1
    • The small screw that was taken out at the beginning can be screwed back into the device.
  7. LG Tone Pro HBS750 Magnet Replacement: 7 단계, 이미지 1/1
    • Push the small rubber piece back into place over the screw.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Andrew Oglesby
회원 가입일: 03/31/15
246 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-2, Shastany Spring 2015 UMass Dartmouth, Team 2-2, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Thanks for your instruction. Tell me please what is the thickness of the ear cords is it possible to connect them back after it was teared off? I want to buy broken on the ebay and fix it but I can't understand if it possible to fix it without looking on the cords.
macosrus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 2,878
