필요한 것
First, see which side speaker needs to be replaced.
Locate the hidden screw as shown in the picture and remove the rubber piece with tweezers.
Remove the screw using a Philips #00 screwdriver.
Using a guitar pick or any opening tool, open the frame of the headset.
Using a Philips #00 screwdriver remove the screw holding the motherboard in place.
Slightly push back on the speaker back housing so the speaker can be pushed out as seen in the pictures.
Once the speaker is out of the way, the hidden screw can be removed using a Philips #00 screwdriver.
Using a pry/opening tool, slightly lift the speaker and motherboard out of place.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 8개
Thanks for such a thorough guide! Would you happen to know where I could find replacement parts without buying whole units on ebay?
Your welcome! Not sure where you can buy just replacement parts at the moment. Best bet would be to buy a unit for parts on ebay or amazon.
I can't hear noise from my left earbud of my lg tone ultra plz tell me how can i fix this problem.few months ago my headphone were working well but after they got in the hands of my nephew accidentally first the sound become disbalance like right earbud can be louder than left one,but after time passes the sound in the left earbud comes to zero and now there is no sound coming out of left earbud ….I can't buy new headphone i would like to repaire it ….!!!
Soak the earbuds in rubbing, isopropyl, or ethanol at 50-70% concentration for an hour. Let it dry out for an hour. The solution will remove salt and other residue from sweat, which causes one side to lose sound over time.
Still no info on replacement parts?
rezinkillz - 답글
