주요 콘텐츠로 건너뛰기
LG Treasure Auxiliary Port Replacement
필요한 것
  1. LG Treasure Auxiliary Port Replacement, Battery: 1 단계, 이미지 1/2 LG Treasure Auxiliary Port Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Auxiliary Port Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Auxiliary Port Replacement, Auxiliary Port: 3 단계, 이미지 1/2 LG Treasure Auxiliary Port Replacement, Auxiliary Port: 3 단계, 이미지 2/2
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Auxiliary Port Replacement: 4 단계, 이미지 1/3 LG Treasure Auxiliary Port Replacement: 4 단계, 이미지 2/3 LG Treasure Auxiliary Port Replacement: 4 단계, 이미지 3/3
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
david amirahmadi
회원 가입일: 02/15/18
585 평판
안내서 5개 작성하였습니다
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 250
