주요 콘텐츠로 건너뛰기
소개
This guide will explain how to replace the rear camera on the LG Treasure.
부품
지정된 부품이 없습니다.
  1. Make sure the LG Treasure is turned off. Pull off the back cover from the phone using the groove on the bottom right side.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. Remove the battery from the phone by lifting up on the bottom end of the battery.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. Remove all 9 of the 3 mm Phillips #000 screws from the digitizer. Work your way around the edge of the phone, gently prying the digitizer off the phone.
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone. Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
david amirahmadi
회원 가입일: 2018년 02월 15일
561 평판
안내서 5개 작성하였습니다
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 146
