주요 콘텐츠로 건너뛰기
LG Tribute 5 Motherboard Replacement
필요한 것
  1. LG Tribute 5 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 LG Tribute 5 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: 2 단계, 이미지 1/3 LG Tribute 5 Motherboard Replacement: 2 단계, 이미지 2/3 LG Tribute 5 Motherboard Replacement: 2 단계, 이미지 3/3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 LG Tribute 5 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 LG Tribute 5 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: 4 단계, 이미지 1/3 LG Tribute 5 Motherboard Replacement: 4 단계, 이미지 2/3 LG Tribute 5 Motherboard Replacement: 4 단계, 이미지 3/3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: 5 단계, 이미지 1/2 LG Tribute 5 Motherboard Replacement: 5 단계, 이미지 2/2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: 6 단계, 이미지 1/2 LG Tribute 5 Motherboard Replacement: 6 단계, 이미지 2/2
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: 9 단계, 이미지 1/1
    • Gently pull up and remove the motherboard using the iFixit opening tool.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Renee Dawn Nelson
회원 가입일: 04/22/19
454 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G6, Cardinal Spring 2019 UW Tacoma, Team S1-G6, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 388
