주요 콘텐츠로 건너뛰기
LG Tribute 5 Speaker Replacement
필요한 것
  1. LG Tribute 5 Speaker Replacement, Battery: 1 단계, 이미지 1/2 LG Tribute 5 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Speaker Replacement: 2 단계, 이미지 1/3 LG Tribute 5 Speaker Replacement: 2 단계, 이미지 2/3 LG Tribute 5 Speaker Replacement: 2 단계, 이미지 3/3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Speaker Replacement, Front Speaker: 3 단계, 이미지 1/3 LG Tribute 5 Speaker Replacement, Front Speaker: 3 단계, 이미지 2/3 LG Tribute 5 Speaker Replacement, Front Speaker: 3 단계, 이미지 3/3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Speaker Replacement: 4 단계, 이미지 1/3 LG Tribute 5 Speaker Replacement: 4 단계, 이미지 2/3 LG Tribute 5 Speaker Replacement: 4 단계, 이미지 3/3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Speaker Replacement: 5 단계, 이미지 1/2 LG Tribute 5 Speaker Replacement: 5 단계, 이미지 2/2
    • Gently remove the mid-frame using an iFixit opening tool.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Speaker Replacement: 6 단계, 이미지 1/1
    • Using an iFixit opening tool, gently pull up the front speaker from its compartment located on the top of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Renee Dawn Nelson
회원 가입일: 04/22/19
454 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G6, Cardinal Spring 2019 UW Tacoma, Team S1-G6, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 151
