주요 콘텐츠로 건너뛰기
LG Tribute HD Display Replacement
필요한 것
  1. LG Tribute HD Display Replacement, Battery and SD Card: 1 단계, 이미지 1/2 LG Tribute HD Display Replacement, Battery and SD Card: 1 단계, 이미지 2/2
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Display Replacement: 2 단계, 이미지 1/2 LG Tribute HD Display Replacement: 2 단계, 이미지 2/2
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Display Replacement, Flex Cable: 3 단계, 이미지 1/2 LG Tribute HD Display Replacement, Flex Cable: 3 단계, 이미지 2/2
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Display Replacement: 4 단계, 이미지 1/3 LG Tribute HD Display Replacement: 4 단계, 이미지 2/3 LG Tribute HD Display Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool, remove the antenna extender from the bottom.
  5. LG Tribute HD Display Replacement: 5 단계, 이미지 1/2 LG Tribute HD Display Replacement: 5 단계, 이미지 2/2
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Display Replacement: 6 단계, 이미지 1/3 LG Tribute HD Display Replacement: 6 단계, 이미지 2/3 LG Tribute HD Display Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
  7. LG Tribute HD Display Replacement: 7 단계, 이미지 1/3 LG Tribute HD Display Replacement: 7 단계, 이미지 2/3 LG Tribute HD Display Replacement: 7 단계, 이미지 3/3
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
  8. LG Tribute HD Display Replacement: 8 단계, 이미지 1/1
    • Disconnect the LCD from the motherboard with a plastic opening tool.
  9. LG Tribute HD Display Replacement: 9 단계, 이미지 1/2 LG Tribute HD Display Replacement: 9 단계, 이미지 2/2
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
  10. LG Tribute HD Display Replacement: 10 단계, 이미지 1/2 LG Tribute HD Display Replacement: 10 단계, 이미지 2/2
    • Use your fingers to remove the flex cables from the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aalia Mohammed
회원 가입일: 02/14/18
448 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 회원
USFT-NANCE-S18S1G3
4 회원들
안내서 20개 작성하였습니다
댓글 5개
Just a note that the flex cables are stuck pretty well to the case. I didn’t rip them but I used a little heat from a hair dryer to soften the glue a bit.
christophergosnell - 답글
I somewhat agree with christophergosnell on this one but I did manage to lift up the ribbon cables using both my fingernails and a small, then, flat head screwdriver at just the right points. there is also a ribbon cable near the bottom of the phone that I had to transplant that is shown but you don’t include a picture of you even attempting to remove it. I didn’t pay attention what it connected to but I just made sure it went in the same spot on the new screen assembly. Other then that a pretty decent guide.
Robert Surles - 답글
Many thanks to the previous comments! The guide is very helpful but could use more detail. I missed the ribbon at the bottom and couldn’t figure out why my speaker wasn’t working. I spent two hours taking the speaker in and out and re-bending the contacts to improve the connection until I checked the comments here and noticed the other ribbon. It was hard to get off so I used a heat gun on low just long enough to soften the glue and then I was finally able to get it off. This solved the speaker problem and all is working well.
James Stephens - 답글
I also used a blow dryer for heat , and small jewellers screwdriver to transfer the ribbons. I also used a magnifying glass
dartswinger70 - 답글
I have reassembled my phone, and it works! Success!. Yes, the disassembly was going smooth, until the ribbon transfer. That's when I stopped, read the comments about using a hair dryer for heat etc. It also helps to have the tools shown in the pic, or very small jewellers screwdriver set like in eyeglasses repair kits.
dartswinger70 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 2,985
