소개
In this guide we will teach you how to properly remove and replace the flex cable in the LG Tribute HD LS676. The flex cable or cable ribbon is a small delicate cable that is connected to the motherboard. It should be handled cautiously since it can be easily damaged by an applied force.
필요한 것
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
다른 한 분이 해당 안내서를 완성하였습니다.
