주요 콘텐츠로 건너뛰기
LG Tribute HD Headphone Jack Replacement
필요한 것
  1. LG Tribute HD Headphone Jack Replacement, Battery and SD Card: 1 단계, 이미지 1/2 LG Tribute HD Headphone Jack Replacement, Battery and SD Card: 1 단계, 이미지 2/2
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Headphone Jack Replacement: 2 단계, 이미지 1/2 LG Tribute HD Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 1/2 LG Tribute HD Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 2/2
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Headphone Jack Replacement: 4 단계, 이미지 1/3 LG Tribute HD Headphone Jack Replacement: 4 단계, 이미지 2/3 LG Tribute HD Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. LG Tribute HD Headphone Jack Replacement: 5 단계, 이미지 1/2 LG Tribute HD Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Headphone Jack Replacement: 6 단계, 이미지 1/3 LG Tribute HD Headphone Jack Replacement: 6 단계, 이미지 2/3 LG Tribute HD Headphone Jack Replacement: 6 단계, 이미지 3/3
    • Use plastic opening tool to pry up the flex cable from the back panel.
    • Flip over and push on the back side of the headphone jack to dislodge it.
결론
Jerry Koenig
회원 가입일: 02/14/18
679 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 회원
USFT-NANCE-S18S1G3
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 7
전체 시간: 605
