소개
This guide will teach you how to properly replace the motherboard in the LG Tribute HD LS676. The motherboard is a key component that connects and controls all the other phone components. Caution should be taken when replacing it since it is a delicate component that can be easily damaged. Replacement of the motherboard will result in loss of old data and documents previously stored on the phone. It is recommended to externally back-up any important data from the phone before proceeding to replace the motherboard.
필요한 것
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
다른 2명이 해당 안내서를 완성하였습니다.
