주요 콘텐츠로 건너뛰기
LG Tribute Rear-Facing Camera Replacement
필요한 것
  1. LG Tribute Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 1/2 LG Tribute Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 2/2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Rear-Facing Camera Replacement: 2 단계, 이미지 1/1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: 3 단계, 이미지 1/2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: 3 단계, 이미지 2/2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Rear-Facing Camera Replacement: 4 단계, 이미지 1/2 LG Tribute Rear-Facing Camera Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: 5 단계, 이미지 1/2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: 5 단계, 이미지 2/2
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gustav Wolter
회원 가입일: 01/25/16
196 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 623
