소개
This guide will assist in successfully replacing the LG Tribute touchscreen.
필요한 것
Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
When the frame is completely free, remove all of the glue.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 4개
thank you for all ypu work at web site
Can you peel away lens without taking apart ?
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - 답글
I messed up the speaker is there a way to replace or fix it
