주요 콘텐츠로 건너뛰기
LG Tribute lower media Speaker Replacement
필요한 것
  1. LG Tribute lower media Speaker  Replacement, Battery: 1 단계, 이미지 1/2 LG Tribute lower media Speaker  Replacement, Battery: 1 단계, 이미지 2/2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute lower media Speaker  Replacement: 2 단계, 이미지 1/1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute lower media Speaker  Replacement, Mid-panel: 3 단계, 이미지 1/2 LG Tribute lower media Speaker  Replacement, Mid-panel: 3 단계, 이미지 2/2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute lower media Speaker  Replacement: 4 단계, 이미지 1/2 LG Tribute lower media Speaker  Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute lower media Speaker  Replacement, Main media Speaker: 5 단계, 이미지 1/2 LG Tribute lower media Speaker  Replacement, Main media Speaker: 5 단계, 이미지 2/2
    • Use a plastic opening tool or your finger to carefully disconnect the speaker.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Marissa Eubank
회원 가입일: 01/25/16
592 평판
안내서 3개 작성하였습니다
댓글 3개
That's cool how did you get this stuff planned it is awsome.
Taziah brown - 답글
This is a brand new phone. Now I have to repair it? Something VERY WRONG with this picture! Is that the best sprint can do?
Ron Lieser - 답글
Brand new out of the box phone and I have to repair the speaker. I don't think so!
Ron Lieser - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 8
전체 시간: 920
