주요 콘텐츠로 건너뛰기
LG UD501KOJ5 Dehumidifier Sensor Replacement
필요한 것
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: 1 단계, 이미지 1/2 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: 1 단계, 이미지 2/2
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: 2 단계, 이미지 1/2 LG UD501KOJ5 Dehumidifier Sensor Replacement: 2 단계, 이미지 2/2
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: 3 단계, 이미지 1/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 3 단계, 이미지 2/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 3 단계, 이미지 3/3
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: 4 단계, 이미지 1/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 4 단계, 이미지 2/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 4 단계, 이미지 3/3
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: 5 단계, 이미지 1/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 5 단계, 이미지 2/3 LG UD501KOJ5 Dehumidifier Sensor Replacement: 5 단계, 이미지 3/3
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: 6 단계, 이미지 1/2 LG UD501KOJ5 Dehumidifier Sensor Replacement: 6 단계, 이미지 2/2
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
결론
Gabrielle Campbell
회원 가입일: 05/12/21
133 평판
안내서 1개 작성함
York University, Team S1-G3, O'Regan Summer 2021 York University, Team S1-G3, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G3
1 회원
안내서 1개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 53
전체 시간: 1,893
