주요 콘텐츠로 건너뛰기
LG Ultimate 2 Digitizer Replacement
필요한 것
  1. LG Ultimate 2 Digitizer Replacement, Battery: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: 2 단계, 이미지 1/1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: 3 단계, 이미지 1/1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: 4 단계, 이미지 1/2 LG Ultimate 2 Digitizer Replacement, Digitizer: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: 5 단계, 이미지 1/2 LG Ultimate 2 Digitizer Replacement: 5 단계, 이미지 2/2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: 7 단계, 이미지 1/1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: 8 단계, 이미지 1/1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: 9 단계, 이미지 1/1
    • Pry the screen off after all pieces have been loosened from the adhesive.
결론
Devin Isenhower
회원 가입일: 03/21/18
329 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G2, Baechle Spring 2018 IUPUI, Team S5-G2, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 387
