소개
In this guide, you will learn how to replace the digitizer on your LG Ultimate 2. This is going to require you to use a plastic spudger to loosen the screen, your hands to pull the screen off, and a screwdriver to unscrew the screen from the rest of the phone. You need to be careful when removing the screen as it is attached to a data cable that could sustain damage.
필요한 것
Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
거의 끝나갑니다!
결론
